dsmryder
Android Expert
well I had made a post before about me getting free 3g. Well it had worked on both cm7 and cm9(what im now using) and just last week it finally stopped working and now everytime I turn the data on my bars go from 3 all the way to an x for no service and it keeps doing that bouncing up to 3 down to x and I also want to go on to say that everytime i tick data on and my screen powers off, i hit the power button but nothing shows up so I always have to do a battery pull and completely disable the data.
Any suggestions of what the problem could pertain too?
I also tried factory resetting on a plain slate and going back down to cm7 and the same problem persists.
My diagnostics are simple. Make a nandroid backup and flash a known good ROM. I would avoid any add ons untill the testing is over. If the problem persists then it's logical that the problem has nothing to do with the ROM itself.
I know it's not very helpful, but it's all I got.
) it'll help out a lot better but that's up to you then again it could just be the phone too
But I have found that my 3G works, though not ALL the time. Obviously I can't make calls or send text messages, but at least with 3G I can keep in touch with my girlfriend through Facebook Messenger
