Not having that issue
Maybe you're having an outage? Similar happened to me not long ago. No matter what rom it didn't have service.
I love the rom, but I would like a music widget... is there anyway you can add one, or how can I add it myself?
Whenever I try to check my voicemail and then check contacts while on the call... it gives me an error: unfortunately the process android... has stopped working!
Thanks but still:Visual voicemail works. And you can Dial 1. I am not having these issues. Try reflashing. Make sure you wipe all partitions b4 flashing
Widget is for sense only, as sense is removed it will not give you the widget. you must download an alternate music player or a music widget control app.
idk about fm radio
idk about your voicemail issue, mine works
Screenshot hold the power button then press screenshot
Hi, I am loving your rom, but the only thing I want to change is the neon blue color. Is there an option to change the color, that I am missing, or is there a build you can make to change it to the lighter ICS blue?
