FoxyDrew
Anyone else on 1.4 having issues?
Me 4g and wifi wont even turn on?
Edit i flashed a the mac kernel and it fixed everything. So the problem lies in the kernel of your ROM.
really glad you like it
Did you format all partitions. And wipe dalvik b4 you flashed?
I just used the "wipe all partitions (exept sd card)" option in 4EXT and i usually do it twice. Am i supposed to do something else?
It seems that you two are the only ones having issues with WiFi and 4G. Flash JMZ KERNEL right after a fresh install and reboot. Make sure SMARTFLASH Is enabled tell me If that fixes your issues
Jmz kernel. http://db.tt/lECHmaG9
It fixed it. But i had already done that with MAC kernel and i
t fixed it. The point was it didnt work stock
