Maybe they are s on and don't have smartflash? I know it can cause issues like that.
nsciucco,
Again just my two cents man. When you work hard and release a ROM your going to hear complaints of people not working, or people that tell you to change this or change that At the end of the day this is your baby, and you sir can do what ever you want
Hey guys. I think I may have found the issue with your 4g and WiFi. This is a theory. Unzip the ROM. Open the system folder. Delete the 4EXT folder. Zip back up and Flash.. I will have a update ASAP....That actually shouldn't be in there. It's my bad. My theory is it's messing with the ROM flashing correctly because you're S-ON. that folder is really only meant for me. I forgot to delete it before distributing. I also believe this is the reason that G60'S theme was overwritten.
FIXED IT !!!!!
Ok soo I too was thinking about the 4ext.
Soo I went back installed 1.2 version of the ROM loaded it, then installed the 4ext recovery app from the site. . The free one, ran the 4ext recovery upgr one time updated it. . then rebooted into recovery.
"Origionionally I got an error once where the 4ext recovery was giving me an error saying it was not configured and told me to run it when in the ROM. . soo """"
anyway soo now I wiped everything inculding format SD card then toggled usb within the recovery transfered the NEW 1.4 mobster rom over to the SD card which was empty. . made sure nothing elsee was on the sd card. . installed the ROM and walla restarted and whoooop it works.
So you are running 1.4 with no issues?
Scratch that. Had to use a empty memory card to flash it.
