Hey man, just wanted to say that this is an awesome piece of work and it actually turned my phone into something I wanted to use. First time rooting flashing a ROM (though I don't know if I'd ever need to switch haha. Quick question though, I was playing with the wallpaper settings and I wrote over the stock one that comes with the ROM upon installation. I looked inside the zip for a copy of it but I can't seek to find it.
NEW UPDATE. I HIGHLY RECCOMEND EVERYONE FLASH THIS IF YOU ARE ON 1.4. JUST BACK UP DATA BEFORE HAND. AND RESTORE AFTER FLASHING AND REBOOTING NEW VERSION.
Just wanna say thanks for the awesome ROM. 1.4.1 fixed all my issues and my phones running at my best, this is probably the only ROM ill ever try again.
Ok, just flashed this ROM last night due to the fact that JB ROMS do not have 3D and 3D is a must for me.
Like I said, I flashed this ROM a few hours ago but I'm sorry to say, the battery life SUX!
Also, my wifi and bluetooth do not work any more. WTF? This isn't looking good. I'm starting to get kranky and you guys don't want to see me kranky.
UPDATE: Dropping calls now left and right. I think I will have to start looking for another ROM. This ROM is not ready to be used as a daily driver yet. OP, you will probably want to make a note on the title saying this ROM is still a Beta or something.
Help us help you.
Are you S-On or S-Off?
If S-On, did you flash the kernel on its on with fastboot, or are you using 4EXT with SmartFlash enabled?
And battery will suck on any ROM, depending on how much your phone syncs to google, how long you play with it, screen on time, etc...So more details on that would be great.
What's S-On or S-Off? Are you talking about my screen?
No. S-On vs S-Off is basically a security flag. If you are S-Off, you can flash new hboots, radios, etc.
If you are S-On, you can't, and kernels (usually) need to be flashed separately.
I'm assuming you're S-On. I'd recommend using 4EXT recovery, and enabling SmartFlash. Then flashing ROMs. Else...you're going to get this issue for a bit with wifi and such.
Did you do a full wipe before flashing? This ROM is rock solid. It also has the best battery life of any ROM i have tried. Your problems are not ROM related.Ok, just flashed this ROM last night due to the fact that JB ROMS do not have 3D and 3D is a must for me.
glad you like it. I am actually gonna include them in the next update . Ive been getting a ton of requests for them..lol... . and maybe live wallpapers too. If I feel like it. Im kind of against them because they suck up RAM and battery, But a lot of peeps have been asking
