Not sure if this is ROM related but since the install of this last ROM I have had issues with GPS apps, only recently with Google + app updated it will not run or start either. In addition I use the STRAVA app for my biking trips and it wont start claiming "Your device does not seem to support Google Play Services", I am able to start it but the second I hit record trip it crashes. . which is when it accesses the GPS. . The only reason I think all three have the same issue is when trying to use Google My Tracks wont work either it closes when you attempt to start a trip which is when the app attempts to access the GPS. . . SOoooooo anyone have any issues like that?
Yeah and also Google Keep does not work either.
Even if I move the apps to the SD card it makes no difference. . .
just tried google+ and google keep. Both work fine.. Never used the other two. Did you restore them from titanium or somkething else like that? try freshly installing the apps.. In my opinion titanium backup is usless when switching ROMS.. It may " work"
but people always tend to have issues. And even though you were on My ROM before. This is a completelry new build with a different kernel
This ROM has the same 3g icon bug found in that other Mobster rom.
what's the bug consist of? bet it's a simple fix![]()
It's flips back and forth from the aosp icon to the sense icon style.
I can't seem to find a way to turn fastboot off either.
Hey nega since your online can i ask you something? It is off topic but have you done the evo v 4g fix everything and turn it into a evo 3D via radio/prl update along with hboot downgrade to 1.04???
Run the RUU And get back to stock. Take both OTA updates. Then flash recovery. Then this ROM. Let it boot up. Then change your hboot to jbear 1.5
gimme a few I'll pm you the neccesary files
Whole process will take 1 hr. Ramjet or Brian will probably ninja in here soon with the files and all the info you need. Lol
