@nyssa: The 0808 builds had some experimental code, but you are the only one reporting these issues. The latest 0810 build has been reported so far to be the stablest yet.
Here are the proper steps for a full wipe and restore:
1) With phone still booted up, use Titanium Backup or MyBackup to backup your apps
2) In recovery, first create a nandroid backup
3) Still in recovery, go under mounts and format the following: data, boot, system, cache
4) Still in recovery, flash the ROM zip file, then the gapps zip file, then reboot
5) Once your phone boots up, and you get through the Google sign-in, go to the market and download Titanium Backup
6) Once Titanium Backup is running, restore your apps, NOT SYSTEM APPS, AND DO NOT RESTORE DATA YET.
7) Reboot
8) Using Titanium Backup, restore apps that had data you need, BUT STILL DO NOT RESTORE SYSTEM APPS OR SYSTEM DATA!
The two main causes of issues after flashing a ROM are improper wipes (always format when coming from a different ROM), and improper restoration of apps (never restore system apps or system data). The next most common cause of issues is bad downloads, so check the md5sum.
@yogi: I wish all phones had the exact same capabilites, would make things easier for bug tracking!
@AndyOpie: As always, thanks for testing the builds, and thanks for helping everyone out!
