JerryScript
Android Expert
Look up DarkTremor's apps2sd
Does link2sd work
It should, but I have received reports indicating you may have to run the setup scripts after each new flash.
Just updating. I'm still having problems (but not as bad) after i reflashed the rom via Clockwork Recovery v3.2.0.1. I wiped everything that AndyOpie150 has said, flashed the rom, then flashed gapps. I then rebooted and started my phone. Phone started up and before i installed anything, i went into settings and entered my wifi passcode. My phone will connect to my router for 3-4 mins then automatically disconnect and reconnect. (It does seem to reconnect easier. I've noticed it does not get stuck at "Obtaining IP address" as much.) I also tried setting up a spare wireless router that I have, but my phone will still connect for 3-4 mins then start the cycle over again.
I've also noticed that my data connectivity is behaving strangely. It seems to prefer 1x rather than 3G. At my work I have signal strength of around -75 dBm, data will fluctuate between 3G and 1x. When connected at 1x, mobile network type is CDMA - 1xRTT. Maybe this and my wifi problems are related?" Any ideas?
Look up DarkTremor's apps2sd![]()
Jerry was talking about my last build and the wifi tweak I added.
I don't have the wifi problem that some poeple are having, but I did hear back from one person saying that it did fix there wifi issue. I would like some more feed back, so could you do a quick flash of my ROM to see if it fixes your issue? Just reboot into recovery make a backup, then wipe everything., then format everything except SD card, flash my ROM, reboot, test wifi, reboot back to recovery, restore you backup. Let us know if it worked for you.
Thanks for the help!
I'll check on those setting for my next build...Thanks for the feed back!I flashed your ROM. I like having the -2 to +2 exposure settings, but it's not perfect yet. The default (0 setting) is unchanged. It's still darker than it should be. All of the exposure settings work, except +1 and +2 are reversed. (+2 should be brighter than +1).
I really like having Launcher Pro preinstalled. That's the launcher I use anyway. Saves me some time.
I'll keep testing your ROM. Everything except the camera works great so far...
Good news...Thanks for testing it out!Quick update after flashing BobZhome's ROM. Not sure what you did, but definitely not having the wifi issues anymore. Connection seems solid, haven't lost connection once. Very exciting news! Thank you. Will continue to test and check other aspects of the build as well.
After you connect to computer, in the pull down, select USB connected. A window will pop up. The Android guy with a USB connection for a Hand.does any one seem to be able to connect via usb ... for some reason i cant .. do i have to change some thing in the settings
I forgot that one, and your the one who told me about it.(I hate getting older sometimes)And if for some reason you don't get the notification about USB connection in the dropdown, go through settings:
settings>>applications>>development>>(check or uncheck)USB Debugging
Once you check or uncheck USB debugging, you should be taken to the sdcard mount screen.
Just uploaded experimental builds with wifi tweaks, bootsound, camera exposure tweaks, reset of death under privacy settings removed, and video icon added to app drawer. To change the bootsound, change or remove the following file:
/system/media/android_audio.mp3
See the OP for changelog and links to new experimental BACKside build, Green Machine Theme to match it, and a new GreenMachineLean package that has most of the bloatware removed, and the green machine theme added in for an easy one flash install.
