JerryScript
Android Expert
Thanks, I fixed the link text in the OP to say 08082011
Seems to be working so far. My wifi hasn't disconnected after being idle for a while.
The camera still needs work (like you said). The default exposure should be what's +1 now. That would fix the dark camera problem. Also, +1 and +2 are reversed. +2 should be brighter. It's very close to being perfect. The dark camera is the #1 thing that's bothered me since flashing aospCMod a few months ago. Your ROM and BobZhome's ROM are the first that have at least attempted to fix it.
What is "added video icon to app drawer"? I'm using Launcher Pro. Are you talking about the green "Videos" icon? Not sure what you're talking about.
[edit]I'm trying to remove android_audio.mp3 using File Manager, but it wont let me do anything to it. I click delete, it says "Could not delete". I click rename, it says "Could not rename". I click move, it says "Could not move" etc.. Is there another program I'm supposed to use to get rid of it?
, but you can enable it using eollie's script.It's not the iPhone, because Verizon's version of the iPhone works with send & receiving MMS. It's AT&T that's the problem!Yep, another reason to hate iPhones!![]()
You have xionia recovery installed,don't you. It doesn't work to well with the IHO ROM's try installing ClockWorkMod v3.2.0.1(not3.2.0) .Then make sure you wipe cache partition,Dalvik cache,wipe data/factory reset.Then format boot,system,data,cache. Once this is done you only have to wipe cache and dalvik cache to install a update.So I really want to continue using this ROM, mainly because I'm a sucker for that awesome screen on/off anim and the ease of screenshots...plus, who doesn't love Gingerbread?!
But I've found that this ROM is very, very unstable on my phone. I've been getting lots of force closes, especially with ADW.Launcher (which I never had issues with when running Bumblebee!), and now it's started randomly rebooting. A fresh install did nothing to alleviate the problem - I reflashed yesterday night and I'm still getting all of the same issues.
Can anybody help me fix the issues I'm having? Like I said, I want to continue using this ROM, but if I can't fix these things I'm going to have to go back to Bumblebee....
Andy, for some reason VM has issues receiving mms from iphones. This been discussed on numerous threads, both here and on other forums. It has nothing to do with the rom, it does the same thing on stock. However, I have a friend on at&t with a windows7 phone and have no problems sending and receiving mms from her.
SORRY for assuming. It's just that your symptoms are the same as using the xionia recovery with this ROM. Did you wipe everything mentioned? Did you install the theme with the ROM? If you installed the theme with the ROM then try installing the ROM only. Wait till you get it just how you like it with apps and what not(just don't overclock it yet). Reboot a couple of times then install the theme. Should cure what ails it.I don't have Xionia. I use CWM.
