cdunkle584
Member
Yep. Twice.You are clearing your cache and dalvik cache before flashing correct?
I just tested, and they all worked fine, though I don't see much difference with posterize.I think I found a bug.
The color effects in the camera aren't working. Solarize works, but mono, sepia, negative, posterize, and aqua do not work.
Not a big deal since I never use them, but just thought I'd point that out. haha
I just tested, and they all worked fine, though I don't see much difference with posterize.![]()
You didn't think I would leave a plain vanilla camera in there did you?Color effects? I knew nothing about it! Time to experiment!
Edit:: Works great! Never realized that was there. Coolness!
This week, probably tomorrow.So Jerry... When you think we are going to see the ICS transition animations on your rom...? Hehe
Just updated to 01202011 build and so far so good. My only problem with it is the boot-up screen.. No offense or anything but how do I change it back to the old one or something else?
Thanks for the update though! =]
You can change it, and there are video tutorials for how, I'll try to find a link when I get home. Search for unpack boot image optimus v.![]()
I asked the same thing a page back.
You may want to hold off for a bit. Blarf just added PNG support to the bootlogo function. I'm going to pull the change in for my next build.
https://github.com/inferiorhumanorg...mmit/10d08bdc705c86e9ad263f1b9db0dd2f90046f10
Blarf is still the man!
Aw, C'mon! It's not that bad.
Oh, well in that case, after you get Slackware installed on your laptop
OK all you flashaholics, I'll have a new build up today, take a valium till then!![]()
