brotherswing
Android Expert
While Ben is quite correct (42 is the meaning of life) it is not yet known what the question is. Age, however, is a state of mind.
I believe that converter package only works with W7 without service pack-1.I found these instructions. Downloaded boot_screen_log_creation_package. Created my image in Corel PhotoPaint and saved as png. Put it in the RLE folder. Open command window in RLE folder and convert_image_to_rle.bat logo.png. And always get this error.
I'm trying to use this for my boot image. Sized to 320x480
Does it have to be saved as a png with any special parameters? Does this converter work with win 7 64? What is the meaning of life? Am I asking too many questions?
In Gimp, I first set to RGB, then set to indexed at 16 colors. Then you have to convert it to RAW format using ImageMagick. Then you convert it to RLE using to565.![]()
For the new-to-linux crowd, I recommend WiBu. It's a simple Windows installer that creates a virtual partition rather than truly partitioning your hd. Installing and un-installimg is as simple as any Windows program, so even someone who can barely turn on a computer can at least try out Ubuntu via WiBu.I can of course Slackify said Ubuntu directions. I have both OS's available, which do you recommend?
Please help! when booting i get stuck in the boot animation and it retries several times to boot but it wont. im frozen in boot screen please help
Once they get a taste for it, and if they decide they like it, they can migrate to a permanent installation via partitioning and dual-booting. I keep it on most of my Windows boxes, just in case my main box is busy compiling, or I'm not near any linux boxes, and I need to do something in a linux environment.
And you can build Android from source using a WiBu installation, I posted directions in the Building Your Own ROM thread at AC. Just be sure to set the virtual space as large as possible on your machine. If you can't set it to at least 50gig, I would recommend editing the config files so you can (google it).
how do you boot into recovery? im stuck in the booting animation from the phone powered off
Oh good. I was having problems with the battery icon. I will check out the new version immediately.
Edit: OK, still having the same problem. The battery icon is replaced with an android bug. This may be due to my older style screen, I am really not sure. I can provide a screen shot if it will help any.
Going back to Green for now.
Edit: Decided to stay blue (I like blue!), just changed the Battery Status Style from Icon to Percentage. That works.
I am on the most recent build of JerryScripts BACKside, currently running the gm blue theme. It has been working fine until just a few minutes ago. Note that I just flashed the gm blue (after clearing cache and dalvik cache).
I run entirely on wifi, the phone is not activated.
I am sitting right in front of my wireless router, showing a full set of bars on my wireless. In settings, it shows connected.
Nevertheless, my browser crashes when opened, Marketplace insists there is no connection, so does Appbrain and GetJar. I tried rebooting, no change. I am going to try going back to Green Machine. Will post an update.
Any help greatly appreciated.
c
You are correct inasmuch as the theme *should* not affect that at all. In fact, the problem arose right after flashing the new theme, and when I went back to Green Machine everything worked fine. I always check the last thing I did before it stopped working, and usually that is the problem.Theme should not affect that at all. Try resetting your wireless router.
My suspicion is that the theme was developed for the later version of the OV. Too bad, really. I do like blue. The Green Machine is great though, I haven't found anything I like better in terms of layout and design. JerryScript did as great a job on that as he has the BACKside ROM. Great work all around.
Yes, the changelog is already a part of BacksideUpdater.Jerry -
Are you going to add the changelog to the BacksideUpdater app? (I haven't used it yet, so it might already be there...)
It would be nice to see what's changed within the app without having to check this forum post.
I updated to the latest rom yesterday. HUGE improvement in speed (I think my last rom upgrade screwed up something that slowed down my phone).
Everything seems to be working perfectly. Keep up the good work.
You may want to hold off for a bit. Blarf just added PNG support to the bootlogo function.
To Do:
-Add downloads as internal feature using async so as not to lock up the gui
-Add md5sum check to insure against corrupt downloads
-Add list of IHO ROMs and available versions, plan on using simple github text page for manifest
-Add option to wipe/flash automatically
-Add menu options such as show current changelog, show update history, etc
-Make it look nicer![]()
Sounds like one of the following happened:I've got an issue when I try to launch the ROM.
I flashed it and whatnot, it installed apparently, and when it gets to the green android guy with the circle thing, it'll just loop a bit then freeze.
I'm not sure what to do, really. I'm new to this.
