freakboykevin
Is anyone else's phone having trouble connecting to 3G and can't receive nor send message or calls?? Please help.
Hi guys newbie here. I have a question. Do I have to reflash my phone every time there is an update because it take a bit of time to reflash and restore everything so do I have to do this with each update? Thanks
Tried to apply the latest update tonight following Jerry's recommendations on the first page of this thread. I was running his 11222011 build, which I would highly recommend people give a try if you haven't (heck, of course most of you have in this thread probably, LOL).
Anyhow, followed steps 1-7 on the install from a previous build through recovery using CWM-based recovery v4.0.1.5 Upon trying to reboot to system, I can't make it past the boot animation of the android guy. I know something's wrong if it's there more than 10 minutes, so I pulled the battery and powered the phone back on. Upon the second attempt at booting, I received the same results.
Not a OMG!!! moment either time, as I had a good backup of course before starting this. I simply wiped cache and dalvik cache and restored my backup, leaving me running just fine as I was on the prior build.
Just wondering what some thoughts on this might be? First time poster, but been following along for awhile. Picked up the V on the Saturday morning after Black Friday for the $50 Target deal. A rockin upgrade from the painful Intercept I had prior.
Great work on the ROM Jerry! I find the V to be a much funnier modding/ROM'ing phone than the Intercept. It's exciting to see your work, and I like many others I've seen on here respect the time and effort you've put forth. :virtual pint to you good sir:
Ok Ben, I shall perform the steps again and give it a good long while, as I have around 30 applications installed, utilizing Link2SD. Which of course I got setup with the help of the guide on this forum.
Is there a time that I should just say to heck with it and revert back again? I.E. if it continues for an hour or more would it be safe to assume (I know the dangers of assuming) that it won't flash properly?
Well, I did the steps again, and let it run overnight after the reboot. Still get the same results of being stuck at the boot animation screen when I woke up this morning.
I certainly gave it more time than this, letting it run over night!
Checked my md5sum before I ever tried to install the upgrade, and it does match. Just double checked again and it is a valid download.
I've restored from my backup again and back to the prior version. I redownloaded the file and verified it again....I guess I'll try it again at a later point today. This is odd.![]()
Well I tried again, reverified new dowload file to have correct md5sum. Still got the same results. Not a huge issue for me, (other than the fact I'm teased by not seeing the easter egg) as I'm running along just fine on the last version. But it will drive my tech mind mad until I get a grasp on why it's reacting this way.![]()
Just wondering if anyone may have any insight, background is in the quotes above..still haven't upgraded from the 11222011 build, as I've tried with EVERY version of the ROM posted since then with the results being the same as above.As posted in my original post in this thread:
I guess I can always just wipe everything and install this update fresh, but it's a bit of a hassle sometimes with Link2SD and having to restore through TIBU.
I'll probably proceed as you're suggested Jerry, even though it is a pita and I'm stubborn.I know it's a pita, but have you tried doing a complete wipe/format and reflash? First backup your apps with TitaniumBackup or MyBackup, then:
1- Boot into recovery
2- Wipe cache
3- Under advanced wipe dalvik cache
4- Under mounts, format boot, system, data, and cache
5- Flash the ROM's zip file
6- Flash the gapps zip file
7- Reboot
8- Skip singing into your Google account till you enable wifi (so much faster)
9- Enable wifi
10- Under Settings>>Accounts sign into your Google account and sync.
11- Download TitaniumBackup and use it to restore your apps, but do not restore system apps or data!
Be sure to check the md5sum of the ROM's zip file before flashing it. If you still get stuck at the bootanimation, then something is most likely wrong with your sdcard.![]()
Got it, not sure what I've been so worried about if it's really that easy. I know there's been ALOT of changes, that's why I've been trying every version!With link2sd it's just a matter of backing up with titanium backup setting up link2sd to auto link then batch restore and it does it all for you. I have 200 apps and do a fresh install with this every time. There have been alot of changes since 11/22 and I would recommend a clean install of 1-20.
Updated to 01/20. Camcorder is missing from drawer and is not listed in manage applications. Still works when accessed using the switch in the camera app. Tried fresh install, same thing.
Not a fan of the new boot screen. How can I change it back?
If you mean the black and white BACKside IHO, I don't think you can. If you mean the green particles swirling around the Android, you can flash a theme or download Boot Animation Changer from the market.
You can change it, and there are video tutorials for how, I'll try to find a link when I get home. Search for unpack boot image optimus v.![]()
Meaning of life is 42
