t_wilson
That's an interesting experiment.Is this on the motorola triumph you have listed in your info? This ROM is only for the optimus V
no, lol. I had an OV first and I'm going back to it. My MT is crapping out.
Will there be a way to download Green Machine? Or will we have to follow a link for that from else where?NEW METHOD (post 01182012 build)
I'm am in the middle of confirming the issue behind some people's wifi problems. It appears as if a borked wireless.ko module somehow got included in Bob's recent kernel release. Since my instructions do not call for formatting system, and I always follow the instructions I posted so that I can insure the steps work for others, I didn't experience the bug.
Two lessons learned here:
1- Please follow the instructions posted for installing BACKside-IHO, failure to do so will result in greater delays in finding a fix for any issues that may arise
2- Do not use factory reset, even in recovery. I have never recommended a factory reset of any kind for one simple reason, it doesn't just wipe, it overwrites with data from a hidden partition (similar to f11 restore on some PCs). This can cause issues with overlapping data bits. Imagine you have a file that takes up 6 bits, it gets overwritten by a file that takes 8 bits by factory reset. You then flash a ROM that overwrites the same area with 6 bits again. The way filesystems are allocated, this means the other 2 bits may not be overwritten by anything. This lingering data can and does cause issues of all sorts.
I should have a wifi fixed build up in a couple of hours. Check on the new BacksideUpdater for details.![]()
Didn't want you to get bored!^ 3 builds in 3 dayshaha
HA. I do remember reading that in the theme threads but that was so long ago....last weekend. I'll remember that now.The themes have to be for that build. I believe mine and green machine and g19s are all that are currently available for this build.
Didn't want you to get bored!![]()
Forget that cup of coffee, nothing wakes you up faster than a good flash! Here at IHO, we flash more in the morning that most people do all day!![]()
I'm going to sleep for a week!So, Jerry, how long before the next update? If it's going to be tomorrow, I'll wait to update my themes.![]()
So long as there are no major bug reports!![]()
Welcome to ROM Flasher's Anonymous!my family did a flashing intervention on me
