i picked a color but i still dont see anything, i have the newest version
When you picked the color, did you touch the middle of the circle to select it?
Took me a couple tries of frustration followed by a slap in my face lol.
Yes, that was fixed in the 0206 build, time to catch up!I found a reproducible bug in 0131. When you go into the notifications window and swipe across to clear out individual notifications, and if by some reason you don't manage to swipe across all the way, the notifications window locks up. Only way to fix it is to reboot. Can anyone else verify this with 0131 or any other build?
Thanks!
Jerry, I'm sure you've addressed this before, but why don't you included Swype in the builds. This would save us 10 megs of space
You don't have to swipe all the way, but there is a point between swiping too far and not far enough were it can get frozen.
BTW- as with most freeze issues on the status bar and notification dropdown, you can use Notification Restart from the Market to restart it without rebooting!
+1 for FlexT9 here. Probably the best keyboard app I've ever used.Besides, I use FlexT9.![]()
I'm a bit confused. How would including the most bloated keyboard available save space? It would still have to be on internal storage, since it's not signed as a platform app, so it doesn't fit properly in the system partition. Sure you can push it to system, but that's a hack, not a part of a normal build process due to the lack of platform signing (it would break signature verification).
Also, Swype is not open source, so I cannot include it without permission. And though I haven't asked, I doubt if they give out permission to include it in custom ROMs.
I haven't had any issues with animations, that "should" be fixed in the 0212 build. Please let me know what you suspect may be the cause.I started having FC's after integrating dalvik into ROM later. I removed it and the FC's continued so I did a full wipe and reflashed 0212. Now I've had my first lock up with the screen rotation thing and had to remove the battery. I disabled animations now but first time I've had to.
Appbrain has it. It worked fine for me when my notifications sort of froze.Nice I'm going to look for that
I had a hell of a time updating my phone....Link2sd stopped working on me for new stuff so I've filled up my memory until I flash the update tonight.
2. Again on the 1st post, 1st pic. On the top strip, I believe its the status bar, it has a clock in the center. Mine doesn't have any clock. Would be nice to get that installed so I can see what time it is from within apps. Any suggestions?
Also, how many posts till I can post pics? Thanks in advance!
... or the color is probably set to black. Pick a new color and then be sure to touch the middle of the circle to select it.
Updated to the latest build yesterday and this morning I again ran into the screen freeze issue. I went through the following steps and can reproduce the issue at will with the following steps:It appears from the feedback in several forums, that the screen freeze issue is affecting those with ADW Launcher Settings>>System>>Home Orientation = auto
If anyone is experiencing freezes with it set to portrait or landscape, please let us know.
