Atma
Extreme Android User
So I understand that you can upgrade the ROM builds via the updater on the phone. Are there any special steps that need to be taken in order to do this? Any gotchas to be aware of? Is this something that is documented somewhere? Maybe it should be added to the stickied guide to flashing/all things root.
Thanks!
The BACKside updater will download the update for you and it will check the MD5 checksum to make sure the download isn't corrupt. You will still need to go through the steps of flashing yourself. Recovery, wipe cache, etc.
