JerryScript
Android Expert
Extra support for vpn was added in bits and pieces over the past month and a half. I hadn't had the time to test, so I didn't post about it. Glad to hear it's working for you!
Question, I happen to be using the Clockwork recovery ROM, and I was wondering if there was a better one you guys suggested, or is this one just fine to use? Thanks.
c
I rebooted and nothing was working write and my apps are FC'ing like crazy.
Link2SD.![]()
Thanks! I suspected. Here's my problem, though: I currently only have about 400MB left on my SD card, and the tutorial on the "Link2SD and you" thread state that I should make a 1-2GB partition to start with. And here's where my knowledge fails me: is that really necessary? Should I clear my SD a bit to make that size (or get a bigger one)? Could I just make a smaller partition? Or something else?
Thanks, all.
My SD card's still the 2GB stock,.
Do you have your apps backed up? If not, get something like Titanium Backup, then move that backup off your SD card to your computer. Uninstall everything except what you can't live without. Then when you get an 8 gig card, move the backup back to it and restore what you like.
