brotherswing
Android Expert
Jerry, could you please elaborate on how to do this via Titanium Backup? I'm running the pro version of 4.7.7.1 and can't seem to find a fix permissions option? Thanks!
Neither can I.
GUI still gets stuck at times, but not as often as previous build, there are a few performance issues in this build, freezes and force closes occur more often than last 3 or 4 builds, virtual keyboard doesn't stretch in landscape mode sometimes(only happens with non-native keyboard app i believe.if this happens, re-enable selected keyboard, or uninstall and reinstall keyboard. ) had a few random reboots(haven't seen that in a few months), average battery drain has been noticeably increased(for me at least, even though I have decreased my phone usage). And I believe that's about all I have to report for this build.
Yep, was just wondering how it was done with titanium backupYou can go to Advanced section in your recovery. Fix permission is an option in there.
I've got the pro version and I can't find it anywhere. Maybe JerryScript meant some other app?Yep, was just wondering how it was done with titanium backup![]()
Thanks Jerry, I believe TB used to have the option...but I can no longer find it either.LOL, I swear TB used to have a fix permissions option.![]()
I just tested both, and they work fine.Hey JerryScript. Finally had a chance to flash the new build. Everything seems good to me with the exception of the GPS=No go, no way that I've tried.
Also the scrolling screen brightness=No go, is not even highlighted in CyanogenMod settings(the option is there, it's just not selectable). Could this be caused by a theme?
Sssh! That's a bad word around here.
Sometimes file permissions get messed up, and there are lots of ways it can happen. This leads to FCs and freezes.Wait, what does fixing permissions do..? I'm lost sorry >_<
That's the rotation screen freeze bug we've been discussing.Here's a new one half the screen froze nothing would fix it earlier the whole screen froze and was able to swipe and tilt to fix it.
