benslgdroid
rockstar
It's the way memory is handled now. Before all that extra was unusable. It would just think it was free. I recommend link2sd I currently have 164 apps with 72mb free space.
How exactly did you pull this off?![]()
1/31 build. Overclocked to 768/480 interactivex. Making no effort to conserve battery life and using the phone pretty heavily, I still was able to get over a day of battery life. This ROM is awesome. Thanks Jerry
This is this best I can get:![]()
Yes. So long as 3G is enabled, it will be used by processes that need network access while the screen is of if you set it this way.
Testing last year by mmarz proved this to be the most battery efficient method.![]()
We are talking about the intermittent background processes here. Not something like Pandora which will be running all the time. In that case, 3G battery usage is dependant upon signal strength atm.![]()
- That's because it's a gradient transparency, try a fully transparent color.Just flashed this ROM last night, a couple things I thought were kinda worth mentioning.
- When the status bar is transparent there is a 1px white line along the very top of the screen
- My widgetlocker wallpaper doesnt go all the way to the bottom of the screen anymore, it stops about 7 or 8 pixels beforehand and the 7 or 8 pixels left are just black
- Widgetlocker doesnt auto start anymore and any apps on it have to be re-done (kinda annoying with simplistic text, it force closes WL when I try to restore the saved preferences in simplistic text)
- Although the status bar background is a cool touch, it would be even cooler if it cropped images rather than squishing them to fit
Also, whats with the new BACKside bootanimation before the system bootanimation? It could use a graphic designers touch.
But I do love the new optionsthanks for the updates as I am probably not switching to ICS, at least I dont plan on it yet.
Oh ok cool, I just wont reboot my phone much haha.- That's because it's a gradient transparency, try a fully transparent color.
-Don't know about that one, I don't use WidgetLocker, and haven't heard that reported.
-I've been working on incorporating the default cropping tool, no promises though.
-The 1st bootanimation is comprised of 8bit RLE images, and I'm definitely not a graphics designer, so I don't know how to make ones that look nicer. Submissions welcome (no promises I'll use though), 320X480 png 8bit raw, 12 images total.![]()
If we are using a different email app like Enhanced Email, can we uninstall the stock Email app?
