brotherswing
Android Expert
Another step closer to Jerry's ultimate goal, Total Domination of the World! Or maybe he just really wants to give us useful tools to make to whole BACKside experience both easier to manage, and more fun!
The icon issue is probably related to the options I added to the latest build to show/hide icons. I didn't include code for the airplane icon, I'll have to see about fixing that.
@129160: 3G is fine for me, and haven't heard anyone else complain about it. Is it a persistant issue, or does it change over time?
every now and then the icon would just disappear and internet would be gone....
I'll keep an eye out on it today.
Thanks.
btw, what is the process of downloading a rom update?
its not in any of the guides.
If the icon is dissappearing, and you are loosing internet ath the same time, then the icon is dissappearing because you lost internet. Sounds like you have some 3G connection issues in your area atm.every now and then the icon would just disappear and internet would be gone....
Thanks.
Or maybe he just really wants to give us useful tools to make to whole BACKside experience both easier to manage, and more fun!![]()
Noob here. I have a stock phone and updated with the new VM security update. I followed the instructions in the "ZV9 for the technically challenged" thread. I flashed the newest CM7 ROM, gapps, and the green machine theme (in that order).
However, now when I boot up the phone, it's stuck in the flashing Green Android Robot screen that says "Before Flashing Always Backup". After about 30 seconds, the screen freezes. I have to remove the battery to get a response.
Any help would be appreciated!
EDIT: I can still boot into recovery. My next step is to restore to stock.
Wipe phone, flash rom and gapps, reboot phone and let it fully boot, reboot into recovery, flash green machine theme and reboot. If you try to flash theme with rom and gapps with no reboot between it will hang.
You must be patient, young Grasshopper. 30 seconds is nowhere near long enough. The first time you boot your phone after flashing a custom rom it can take significantly longer than you're used to. Wait ten minutes before you yank the battery.Noob here. I have a stock phone and updated with the new VM security update. I followed the instructions in the "ZV9 for the technically challenged" thread. I flashed the newest CM7 ROM, gapps, and the green machine theme (in that order).
That ought to have been long enough...
Did you check the md5 of the file you downloaded? Might be a bad download, might be a bad flash...Trust me, putting the effort in to get this working is so going to be worth it.
Try going into menu-settings-cyanogenmod settings-display, uncheck rotation animation.
Jerry, there seems to be an intermittent issue that when I want to get into my phone, and i hit any button, it displays the home screen and doesn't respond at all. This happens rarely, maybe once a day, and I have to yank the battery to fix it. Any ideas?
