JerryScript
Android Expert
Two Things:
1. What exactly do you need Jerry from LG to get the headphone/mic port fully good? I'd like to attempt to talk to them to get information needed. I really would like my squareup device to work.
2. Using the touch recovery i was able to use cdma workshop to get my MSL code (did you know android debugging is broke in your rom?)
Using the MSL code and touch recovery running I did a backup using the qualcomm of my radio PRL (and probably other junk) and then wrote the latest downloadable spring prl 51085 that I could find (Wife's is 51086 but apparently very little changed according to a website that analyzes changes)
Seemed much easier than doing the virgin updated method recently discussed, and allows you to put any PRL you want. Now I get to see if my battery drains as much at work as usual with data enabled (usually turn it off or I lose 50% or more battery in an 8 hour day) (hint, nice option to be able to enable would be to have data disabled when screen is off after maybe a few minute delay)
1- we need the schematics and associated gpio's for the 3 wire headset jack, as well as the changes to the frameworks (which they are not required to give out, they only have to release the kernel source). I have actually spent a couple of weeks worth of hours investigating this, and it's still pretty unclear exactly how LGE works it. I would like to get it working since so many states are passing hands-free laws, we need a working setup. I've even attempted to use the HTC 3-wire headset codebase, but no luck.
2- android debugging is not broken in BACKside, I use it everyday. If you are referring to recovery, then that's a different story. I'm working on my first recovery now (see the past two pages of posts
Last year I switched to a hybrid PRL that combines a Sprint list, and the VM list. I went from only being able to connect to one tower while at home, to being able to connect to three different towers from there. Note- this doesn't always equal battery savings, since tower hopping actually eats more juices. But if you are lucky enough to have a single tower closer, and the PRL swap allows you to connect to it primarily, then you should notice some battery savings.
