What about volume_down?
Have adb?
adb reboot recovery
or in terminal emulator:
reboot recovery
So many ways.![]()
You must have installed the 04012012 build, better known as the April Fools build.
You can check by going into Settings>>About phone>>Build ID or Build date
Delete /system/media/AprilFools.zip or update to the latest build: 04092012
Just open your app drawer and launch the BacksideUpdater.![]()
Hahaha... I have that build and figured the static was just part of the awesomeness of the rom. Didn't even think twice about it.
I have all but one of those space sets and a number of the other sets. I gave all of my LEGO sets to my kids though.Talking about Lego... been building a bunch of the old set I had as a youngster and placing them on Ebay.
This is a known bug in IHO/CM. Some report that turning the volume all the way down then back up, all during a call, will fix it temporarily.Hi,
I've flashed the latest ROM, completely clean with no apps or data restored other than Contacts, MD5 sum checked on the SD. And I'm finding that the in-call volume on a wired headset is low versus stock. It seems that volume settings above the middle don't actually produce any increase in volume.
I did a search and it looks like a user had this problem a while back, without any resolution; I would post the link but am too new to have permission to do so, it is post #2310 on this thread by Idun Box. Any thoughts?
Love the ROM by the way, a vast improvement over stock.
Yes for terminal.
Not rooted? Then only with holding volume_down+home+power keys from power off state.
Sorry man, that's a well documented issue. You're correct in that it's not BACKside specific, but sadly it's unlikely to ever get fixed until the entire codebase makes the jump to ICS. It already works on the ICS alpha builds. Now if they could get that darn camera to work, BACKside might be trouble!Not to complain, just to document: the headset mic does not work with Voice Search; Voice Search "listens" from the phone mic instead (which doesn't work too well if it's in your pocket!). Seems to work correctly with calls.
Some searching I did suggests this is, like the headset volume gain, also a CM7 issue, not BACKside specific.
Hey JerryScript,
Just wanted to let you know we ported this to the Optimus M
http://androidforums.com/optimus-m-all-things-root/517309-rom-sap-backside-cm7-2-port.html
Very smooth and stable, thanks to you we have a ROM that is synced with CM7 more frequently
Keep up the good work![]()
Looked through your thread and answered a few questions in relation to the rom.
After finally getting the BACKside ROM on my OV, I love it. I can't imagine using anything else now...
Question: How do I get the default BACKside wallpaper image (the one with the green clouds)? I changed it to something else, but it doesn't appear in my wallpaper gallery.
