Root [ROM][WIP] BACKside ROM (CM7) + Green Machine Theme
Once you change the default wallpaper, you CANNOT get it back, this usually happens with a lot of ROMs...the only way to get it back is reflash the phone....unless JerryScript would like to post the default wallpaper he uses from his sources...idk if it works that way though.
I know what you mean. I'm running heavy modified framework-res.apk including the lock screen:
attachment.php
Here you go. I found the default wallpaper. I uploaded this to my imageshack account because it looked to me like the website I found it on has some personal photos of JerryScript. So out of respect of his privacy that's why I did it.
Thank you so much! I apologize for not searching the thread for this info earlier.
Also, as I am a noob, I stumbled upon the Overclocking menu, and it is... glorious. I set my OV to 480 / 748, and it has been stable for a day now.
Not for me everything is good. :D
I don't have an m Im just giving knowledge about the rom I have from my dedicated use of the rom.
What I've found is that 99% of the time when there's no issues on the V, there's no issues on the M either. And kernel related issues on the V wont happen on a port because I am on a different kernel based for my phone by replacing the boot.img ....if I don't replace it, touchscreen wont work.
Hey Jerry, I'm planing on bringing this to the C on androidcentral......the c forum on AF is pretty much dead, actually pretty much everywhere it's dead......not much rom development happening for C users. Just thought I'd let you know. :cool:
I am so proud of myself, I learned how to do a custom boot animation and get it on my phone! check this out, I got it over at xda.
It's so syfi terminal awesomeness.
I keep rebooting my phone to watch it lol.
Been on my mind awhile now, but does anyone else have this issue.. I cannot overclock my CPU at ALL. I am running the 4/9/2012 build.. I've run all the previous builds for the last few months as well. This is a newer phone that came with 2.2.2. Anytime I set the CPU to overclock (at any speed, even 729Mhz), it will lock up and reboot sooner or later. Usually navigation will cause it to reboot 99.9% of the time. Is my phone just not made to overclock? Seems like so many of you overclock without any issues, although maybe you are not using any intensive programs either. I have tried ONDEMAND, SMARTASSV2 and a few other governors without any change in behavior.
On a side note, GPS works great on the phone and always has. Picks up the signal very quickly.
I just tried to overclock my newer phone, it froze and rebooted.
