elgecko
Talking about Lego... been building a bunch of the old set I had as a youngster and placing them on Ebay. LOL
elgecko1989 | eBay
elgecko1989 | eBay
Actually I wouldn't. She owns cast iron skillets.![]()
Today I gave magpie a good test flashibg tvall's iho magpie ROM and it works great. Moves dalvik to /sd-ext and Market can see and update sd-ext apps. The only thing I will miss from Link2SD is sorting/listing apps by location. If this can be implemented in ROMs "Manage apps" applet, let say by adding "sd-ext" and "internal" tabs to it we can get rid of Link2SD for good.
Even fixed QtADB Apps page to list installed and moved apps with magpie.
Jerry, do you read this? I approve!!!![]()
AFAIK, grepping the last_log file is the only way to determine if CWM is being used. And of course, if you flash a new recovery, it won't be shown accurately till after the first reboot (since it's just a log file).In recovery mode only mounts/unmounts and Flash ROM are active. The other functions just doesn't make sense in recovery mode so I disabled them.
CWM stuff works only if CWM recovery is installed on device. It detects presence of /cache/recovery/last_log file and checks if the file contains "extendedcommand" word. If one of the two condidions is false then CWM recovery is not installed and CWM stuff are disabled. BTW if anybody knows a better way to detect CWM recovery installed from within Android OS I want to hear it.
@nijel, turns out my original issue wasn't with recovery, but rather with using RecoverySystem, since it requires the update_package to be on either /data or /cache, I just used an exec instead to write the command file and reboot.![]()
I just added the ability to show/hide the 3g icon in the last build. Looks like I've got some more debugging to do. Sorry for the inconvenience.I tried searching for an answer but hard to do on phone so wondering what I'm not doing right. Made a theme on UOT Kitchen and flashed it via recovery. On reboot the 3g icon alternates between the normal one and the themed one. The signal icon shows the themed one briefly and then goes to the normal one. Running newest backside and have tried theme and rom setting under statusbar tweaks. Thanks for any help
Also tried pushing the files via adb
Settings->CyanogenMod Settings->Interface->Power Prompt, check it.
or
Hold down volume_down+home+power keys till you see LG logo.
