brotherswing
Android Expert
Ouch! Heh, punch cards.....
I seem to recall a User Friendly panel involving punch cards and a leaf blower.
Link2sd don't play nice across Rom updates on some handsets. Ben is one of the users who have to do a full wipe every time or else Link2sd won't work right. Other users (such as myself) are fortunate enough to not have that issue.
I'll look into it.One thing that bothers me about magpie is Market wont see apps on /sd-ext and you wont be able to update them.
Jerry, wondering how hard is adding QPST connect ability to your recovery(like xionia)?
That's one of the issues I'm exploring, hoping an init.d script can fix it.One thing that bothers me about magpie is Market wont see apps on /sd-ext and you wont be able to update them.
No matter how I set it I can't get my phone to vibrate unless it is on silent. I normally have it sound+vibrate or vibrate only. But now (since some time in march) I can't get any settings to cause it to vibrate when the sound is enabled. I've been running 01252012 until sometime last week and then I flashed 04012012.anyone else have the issue with the phone not vibrating when a text comes in? I've tried many different settings, but cannot get it to work. I should also mention that other notifications vibrate fine such as words with friends, etc...
Hey Jerry, have you noticed any issue w/Airplane mode not showing the little airplane icon in the Status bar? I just noticed it recently when I was on an airplane and was curious if maybe there was some setting I had tweaked accidentally. thanks.
I will probably be going back to my 01252012 nandroid from January and see if I can get it working again there.
Try re-flashing the same version that was on it before you updated. If it doesn't fix the problem it's a problem with the wall charger, USB cord, battery, or charging port on the phone.OK..Another goofy question.
My stepdaughters OV had been working fine since I wiped, then rewiped everything know to mankind.
Now she calls me and tells me the phone won't charge. WTH?
I don't remember reading anything about ROM issues having a charging issue. Did I miss something or what? I'm so sick of this d**m phone I could scream.
Thanks for any/all help, suggestions, donated airline tickets, etc, etc, etc...
I'm also running 04012012. Couldn't get it to vibrate at all when a text message came in. No matter what setting it was on. Can't comment if it vibrate when I get a call cause no one calls me. At the advice of Ben I switched to go SMS, and the vibrate function works fine now when receiving messages.
