brotherswing
Android Expert
I've never really tried it, I just thought it was worth a shot.
I've never really tried it, I just thought it was worth a shot.![]()
Oh that works? Ok so back up all contacts to SD card, delete all gmail contacts, restore contacts from SD card, good to go.
You mean I should delete all of those 200 miscellaneous contacts? That would probably take longer than typing in the 60 again, and syncing them.
Oh, right, duhhh... what about the tripling/doubling of contacts once I sync them?
What's ths problem? I scrolled back some pages and sstill don't understand![]()
Sync them once more, and clear Contact storage in All Apps, then uncheck Sync Contacts.?
qft!oh! Export the contacts to csv, and import that file in gmail on a pc! Then you're right there to make any edits you need, then sync the phone with your google account. That would work...
Has anybody installed this http://androidforums.com/optimus-m-...s-management-privacy-control.html#post4265492 ?
PDroid ?
I noticed he made a patch for the BACKside ROM already. This is why I brought it up in the BACKside thread. I have LBE, but might try PDroid as it looks like it might work better.
FYI- I'm going to be spending the next couple of weeks attempting to fix a glaring security hole in Android. Downloads are started without asking the user's permission, resulting in the Not-Compatible drive-by vulnerability to be exploited more and more recently.
Is this a browser issue and can it be avoided by using a browser other than the Android browser?
Go into cyanogen mod settings, display, uncheck rotation animation, reboot. It's a glitch in cm.
