On the cm10 roms is there a way to revert the Korean font caller id to English words? Not trying to sound off topic here...
do we have to install all of the .zips
Is there any other host i can get the latest version of this rom? every time i try to from dev-host it fails at the last second. I can't even get it to work on my nexus or any browser on my desktop.
Thanks in advance.
Anyone have a good link for VerC_Modem.zip?
Links are down
Has anyone got this fixed yet? Phone does not vibrate with incoming calls. I tried Smart Vibrator, but still doesn't work. Any ideas?
Thanks in advance.
Which version are you coming from my phone vibrates. Try changing all you sound settings. Change ringtone notification everything. Turn vibrate on and off a few times. Reboot then try receiving a call.
I had problems with my notifications not vibrating before and I changed all my notification and message settings and it started working again.
https://www.dropbox.com/s/qnfqkjcuiyxkuf8/Lights.zip brightness fix
cm-10.0.0.l0.BobZhome.04222013.zip 4-22 rom
https://www.dropbox.com/sh/a4wrvta07pgji0d/gcEU09B6zg/4g Fix.zip 4gfix
https://www.dropbox.com/s/p0aqcfqvvpsee88/build.prop?m edited build.prop from 4-28
https://www.dropbox.com/s/0sot3ha5evodtbw/FB_HOME.zip?m working facebook and fb home
[THEME] PlayStore 4.0.27 ...plus 13 other G-Apps - Blacked Out or Transparent (04/27/2013) clear or black or almost any color of all google apps like gmail, maps, google now etc.. if you want
the lights and 4g are flashable the buildprop can be overwritten with root browser lite. theres already a buildprop in 4gfix but it isn't edited like mine. also i flashed 4-22 from fresh flash of stock f (may or may not matter)
going on several hours without a single crash or reboot
also don't know if it matters or not but i froze play services with titanium. probably doesn't matter but you will have to do it to use the clear playstore or google will update over it.
thanks to thedemon for the flashables
BTW you still have to flash the latest gapps also. just a reminder.
