colinp123
Member
Here is a different link, hope it works better
[link removed as to not irritate the android gods]
Can you pm it to me so it is not technically hosted for everyone as a mirror?
It still won't download from dev-host.
On a side note: does anyone have a link to the thread about replacing the 1x in BobZ with a 4g icon? I know one exists but I can't find it for the life of me...
swagg422-what is your version,setup,etc.I need to get the vibrate working-thanks
I'm on Pg's build. I have everything checked to vibrate and still nothing.![]()
just pull this file from pg's latest build and put it into bobz build and vibrate should work fine. system/xbin/cm10.tarI'm firmware f with Bobz 5/21 at first my vibrate didn't work for text or calls then I tried these 2 methods to get it working.
Didn't you say that it caused random reboots?
Nope not for me
how to boot to CWM recovery?
Really wishing I could fix this damn vibration on Bobz. I never had this issue last time I installed it..
-------So i flashed PG CM10 and flashed back to stock because I lost 4g service. I then flashed to Bobz and still lost 4g. I flashed back to stock and now have no 4g in stock. Does anyone have an Idea what I should do next? the phone does show the ICCID card number on stock rom and IMEI. I am just running out of solutions. This is the first time I flashed a phone and had a service loss. I have been flashing phones for over 3 years now.
Update: After searching for countless hours and going over everything twice. After re flashing CM10 I now have the 4g data speed on 1x icon. I just couldn't figure out why going back to stock doesn't show 4g or give 4g speeds. Turns out I just needed to flash the ROM like 3 times lol...
What are you talking about
I had the same issue.
When I flashed CM I got "no data connection found"
rebooting, the icons stayed the same, but I now had 4g speeds.
From there I figured out that If I used the toggle to turn wifi on and off, I would lose 4g until I rebooted. Once I knew it was no biggie.
Nope not for me
Yea after I reinstalled everything it works fine now. Must a been something on SD causing it.
