Root [ROM][WIP]CM10.0.0.l0-BobZ
Give me a second to find it but if your speaker blows don't say I didn't warn ya... Just FYI mine rings like stock with the call fix..
Your using the single file jonny found, because I tries that and it still seemed quite low? And which cm are you running, I tried bobz 4-22 and everything seemed like stock sounds but had no brightness control?
This is my file I was going to implement before I discovered xloud worked.. All you need is xloud and the files the way they are in 5/21 nothing else..
Thanks. I'll try and let you know the results.
Edit: I get a security error screen. Something about no morning call.
Don't quote me on this but I think if your trying to install 2nd-init on top of cm it leads to morning call error. You'll have to Unbrick and start over
can someone please tell me how to read my file's on my external sd also i tried to apply themes and they don't work?
flash this zip then try to choose a theme. it's a modified theme manager/theme chooser that just applies it with out you having to change screen density to make it apply
theme_chooser.zip
thanks Johnny and how do i view my folder's in the sd card i have root explore and the file manager that comes with cm 10 also solid explore and cannot view any of the folder's
