App example?
adaway and cydia substrate
Adaway doesn't cause bootloops, but i know that cydia substrate does, but that can be fixed if you hold volume up when you boot.
PlayfulGod's 5/17/2013 build on his wiki page. Not BobZhome's 4/18/2013 build![]()
Have you or anyone else tried the 5/17 rom out yet and how is it running?
Does 5/17 run good with version F?
Its what mine has, only thing I seen is the purple 1080p video.
I cant connect to my home wifi says something along the lines of poor signal. But its excellent signal.![]()
After flashing PG's CM ROM, I can't browse to phone when connecting to computer. I can't find the option to change phone to MTP mode.
Just flashed the new 5/17 build over stock F. only issues are:
- I can now see why people are saying no/low call volume...
- Any music app plays gargled noises and then crashes my device all together.
-apollo
-doubletwist
-winamp
-many others
Thanks for the hard work and thanks in advanced
-apollo
-doubletwist
-winamp
-many others
Hey is the modem C download only supposed to be a couple Kb although media fire says its 18mb?
Sometimes, on the 5/17 build and even the 4/28 build, this will happen and I never get to see the picture. :/
That number, might want to take down picture. Unless she's okay with getting strange text.
i just finished a build and everything seems to work fine besides rebooting to recovery from power menu
Look at my github for modified_du1 i think its named, then look at the commits for the 2nd-init recovery edits.i just finished a build and everything seems to work fine except when you click power then choose reboot recovery it does a factory reset instead of going to recovery. andbody got any suggestions? my head hurts from trying to fix this. if you just click reboot then spam volume on boot then recovery works. i'd be happy if i could just remove the reboot recovery panel
