Swainsmith82
Android Expert
Hopefully one last post here. Are there any reports of the playstore images being blurry?
Yeah Playstore images are blurry.
It's odd how MMS, SMS, and GPS works fine for me, too. If i want the GPS to be 100% accurate i just turn on wifi and it locks immediately.
Here's how i flashed.
a) i came from software F
b)go to recovery
c)factory reset, wipe cache
d)flash rom, gapps and 4.2 keyboard(optional)
e)flash version c modem.
and that's how i flashed it. can anyone comfirm this makes gps work for them?
you all are the most confusing bunch I have ever seen. lol
I have asked numerous times if mms worked, I got told it worked fine. It worked for my wife. SO whats the deal?
And Sworn, you have a inverted Mms.apk or the one I built??
Mms works it just gets hung up every now and then sending and receiving a lot pics in a short time. So I use an inverted one that works 100% of the time.. Plus I like inverted anyway. Like I said for me the only issues are the proximity sensor when making a call, call volume, and I just started realizing that when you lock the screen sometimes the screen while off stays lit up like it would look on a brick.. If I don't noice it, it drains the battery fast
the MMs is inverted in my builds. lol
Well damn.. What about the other issues?
I've not fixed anything else yet.
Yet??!! . So what you're saying here is there's a chance?!?!! Lol
I'll wait for a completed build from you.. I don't want to hassle with resetting up my phone right now.. I am a fan of your work though from my Admire days and think you have better taste about what looks good than most..
I plan on still attempting to fix the issues. Time just has been tight lately.![]()
Hey guy if u have problems with call volume use head phones with a mic and u can hear everything fine it works for me and it gets my by
It's all good I got it where i can here a little better now. Modified the amount of in call volume steps.
How did u do that ?
edit buildprop
What he said ^^
Hey johnny what other changes did you make to the build.prop with avatar besides the density?
not trying to be rude but you should ask that in that thread. but the answer is nothing.
Since 4g obviously works would it just be possible to swap out the pngs in system ui so it shows??
