PlayfulGod
Extreme Android User
Since 4g obviously works would it just be possible to swap out the pngs in system ui so it shows??
yea but then it will show incorrectly when actually on something other than 4g/lte.
yea but then it will show incorrectly when actually on something other than 4g/lte.![]()
try the format internal sd trick. backup music and pictures etc.. first of course. don't ask why this works or why internal sd affects this but it does. you need to flash 6.0.2.7 recovery to format /sdcard (internal sd).
mms-recovery5-recovery6.zip
So this works for bobz 5-21 build?
I think the only real issue i haven't been able to fix is the backlight staying on while the screen is off.
Ok I'll check it out.. Btw i remember reading through here on one of these many pages something about c modem making 4G faster
download the miui launcher but only use the lockscreen and your backlight will stay off. set cm lockscreen to none.
Yeah flashing c modem makes it faster
I get glimpses if what looks like the crt off animation from time to time. Has anyone else seen this? Maybe this could have something to do with the backlight issue. Is it supposed to have this animation?
Yeah there's definitely something with the lockscreen. I noticed when I'm making a call the screen locks sometimes automatically this is why it seems the proximity sensor isn't working right and why when I pull my phone away from my face it won't display the screen . When you select owner information to be displayed it doesn't show on lockscreen either...
The best work around I have come up with so far for the backlight is to set the lock delay after time out to at least five seconds..
iircc crt is pose to be disabled because it caused backlight/wake issues.![]()
theres a setting in phone app settings that fixes proximity. just check keep proximity sensor on
Is it fixed on your build? Im considering jumping ship here. What are the main differences? I saw a few from the screen shots but...
off the top of my head, the data and talk abilty,
i was reffering to the abilty to talk and surf at the same time, bobz can pg can't.
A tiny build.prop change in bob's build made this possible. I believe the same can be done for PG's. If you're running PG's build, try adding this line to your build.prop, reboot, and give it a whirl.
[HIGH]ro.config.svlte1x=true[/HIGH]
