Android?What!?
Well I tried that and it still didn't seem to work..
We seem to be stuck in the same boat you and I.
Is it me but when i view the sms app. I dont see anything like <MMS> or multimedia?
If you are talking about sending one from within the SMS app, start a thread with the person you want to MMS and push the menu button. Attach a picture to have the SMS app automatically convert to a MMS.
Reppard, checkout what I got booted on my OV:
more pic's here: ics pictures by BobZhome - Photobucket
A lot of work still to be done, not much works yet!
I don't have time right now myself, but I think someone should be pulling files from this new update and finding whats new, seems it's helping with FC issues and reboots on stock phones, maybe it has some updates we can merge into cyanogen builds...
http://androidforums.com/lg-optimus-m/456265-optimus-m-update-available.html
Has GPS been fixed in this rom yet? I recall seeing a post that GPS wasn't working through the built in receiver but would over the network.
Try moving and/or deleting the 01mvdalvik file out of init.d, located here: /system/etc/init.d/01mvdalvik, clear market cache and data, reboot recovery, wipe cache/dalvik_cache, reboot.
Try the fix I posted a few posts up, it will fix your issue also.I kept getting an insufficient space on the device error. Didn't really know what caused it but the solution in this thread fixed it for me.
http://androidforums.com/android-ap...nloading-there-insufficient-space-device.html
An app called MarketFix. I think all it does is move Market to the SD.
Why do you need to change the APN?Also, is there any way I could get a working xml file for the apn list? My phone has a blank screen for the APN screen as well. I know I could try flashing and reflashing a stock rom but maybe I can avoid that and restore an xml file directly?
no he means some of the optimus line of phones actually had a fm radio built in, you could tune to the local radio stations.
Not internet radio
