MommysDroid
Member
its the class 2 card that you have but you can move the dalvik to phone to run a bit smoother and your apps will still run from sdcard, just open TE and type su and hit enter, next type a2sd nochache, you phone will than do some crazy stuff, and it will reboot, and you are all done.
Thanks Nutt
I downloaded an app called SD boost and set the cache to 1024 and my phone seems to be a bit less laggy, but it still Sucks!!
Oh well, I will just have to sacrifice space for smooth operation..
