nuttmeg
Extreme Android User
Huh. Never knew about that.
yeah alot been having that issue w after 0509 release, but also depends on there router also.
Ive already tried that with the static IP turned it on and off. The MAC Address and IP Address both say unavailable. I downloaded a wifi manager and that didnt help at all. My GPS and Bluetooth work tho.
Another little issue- Gmail keeps force closing on me as soon as I open it.
sounds like something new at McD's and staples as their routers is what would control that.No biggie, but yesterday when I tried using free wifi at McDonald's and Staples hotspots, I was faced with a web authentication login page. I have never had that before. Is this common with cm7, or is it due to the new IP address in this build? just wondering... Thanks!
did you do a backup? if you did just press Volume up - Send key - & Power button in this sequence it will put you in CWM, & hit restore. you should be fineSo I was going through the process of installing Cynogen on my phone, and booted into CWM Recovery mode and formated all sections it requested an cleared all caches, did all directions step by step but forgot one crucial thing. I forgot to install the Cynogen 7 file cause my door bell rang and a neighbor had a short conversation with me. Assuming I had installed it after talking to him, I rebooted and now I am screwed.
The Phone boots to the white screen with the huawei logo and that is it. I cannot connect to the PC, I tried to fast boot and for the last few hours I have been stuck trying everything to no avail. I am simply pissed at myself for allowing myself to get so distracted and goofing up like that.
I was hoping to find a way to boot CWM straight from SDcard on my phone because that may be the only way to get my phone working again, but found no solution. So now I am on my hands and knees banging my head to the wall and begging for someone's mercy who can assist me.
All original metro files were deleted as were all system files and folder so there is no way to boot into the launcher at all so white screen is all have with the logo.
use this video to flash CWM: ‪How To flash Clockworkmod Recovery 3.0.0.5 to Huawei Ascend‬‏ - YouTubeOkay you were right my dumbness was pressing the wrong button, I had to look at my wife's ascend. What I got after pressing these buttons is the following:
Firmware Update
step 1/2
Unpacking
Updated failed
No CWM but all my buttons are flashing
Okay sp I realized I had the SD card inserted, I removed the card yet still no luck.
Did you wipe data/factory reset and wipe dalvik cache? Also which gapps did you use, should be using 0613 on the latest builds.Hello Everyone. My Name is Andy and Its nice to meet everyone. Im kinda a rookie at this, so dont be too harsh on me. We were all rookies once..
Anyway, I Rooted my huawei Ascend with z4 root successfully. Installed Rom manager and Located the latest cyanogenmod 7 rom file. Placed it in my root of my sd card and used rommanager to install it. Install was successful. got back into rom manager and added all the google apps. First off, wifi would not work. and then gradually, 1 by 1, none of my apps would work. marketplace to make me force close. as would facebook, angry birds, and eventually everything! I was finally able to get Rommanager to run long enough to restore my old rom from clockworkmod. Why did CM7 do this? What steps did I miss? Any help would be appreciated. Thanks so much in Advance!
Wipe all factory reset and clear davik and cache redo the process![]()
no root wont be affected and rom manager is installed by default in CM7. You also can reboot into CMW to install roms either from RM or from the power menu, or from power off by pressing SEND, VOL UP, POWER.Ok, if I do a factory data reset, will that delete my root privilages? Also, Will I have to redownload rom manager from the marketplace in order to install the rom or will it still be on the phone? Thanks everyone for your help..
