K
KOLIO
Guest
Quick question...
If I flash to stock, and try it all from scratch, it doesn't mess with partitions, right?
As long as you don't format the SDcard,you should be O-TAY.From what I gather formatting not only deletes the data on the card,but,deletes the partition as well.
I will 'note' when I mod sumtin using others work.
your last build is not that far of then the one i have know? i dont want my wife to hand me divorce papers if i flash again. i'm getting tired of making it up to her if you know what i mean
. Reading ur posts have started to encourage me to want to try out different builds. You never know until you keep at it
