nuttmeg
Extreme Android User
lol what a tool. Wait, that wasn't you, was it, nuttmeg? Haha j/k
lmfao!
roflmao
lmfao!
ok, I read the same thing about a2sd, it installs apps to sd automatically. But when I go to "Manage Applications" if I click on any app, I can see the menu "Move to SD". So what is going on? Where are they exactly? and how to know which apps are on the phone and which ones are in this special place?
The way it was explained to me is that the phone is tricked into seeing the sd-ext as internal. That's why you still have the option to move to sd. It thinks it's internal.
Ok Thanks, also I read that one can move the launcher back to the phone with TiBU, I have the free version and I can't move it, is it with the paid version that one can?
I dont think tibu and DT's a2sd work well together lolSorry I did'n't explain it right.
I have a free version of TiBU and if I want to move the launcher (Zeam Laucher) back to phone, when I click "convert to system app" it tells me that it requires to use the paid version of TiBU. Unless there is another option in TiBU that I didn't see.
Thanks,so there is no other way to move apps back to phone if necessary? Is it necessary to move the launcher back?
when it comes to moving things to/from the sdcard they kinda override in other in my mind. But then again I dont like tibu so lolhow come?
i unistall mine for ADW Launcher Ex (paid for), & notice everything runs much smoother, even the alarm clock works on sleep mode. oh i'm still on 0727 Rom.+1 Just made LPP my system launcher/froze stock (ADW) w/TITANIUM BACKUP PRO,all is well.Also integrated MARKET UPDATE into ROM.
Got a FORCE CLOSE on MARKET upon UPDATE integration, had to sign in to MARKET just as you would upon installing GAPPS,all is well,MARKET is working just fine.
Probably gonna leave the stock launcher on the ROM in frozen state,it's not taking up that much memory & not consuming any of the other phone's resources.
Yep, I read about that. Check this out also.I've not used amazon apps since it was reported their app is back doored!![]()
so can i just install the gapps-gb-20110613-signed on the latest biold for CM7. Because im having to much trouble with gapps_update-2.3.5-gb-20110725-signed . Or is it mandatory i must install the latestest? (if the new one just has the new market then i can just install the apk!
I used 0613 just fine.
Skimmed the threads but couldnt find an answer.. Was having strange issues with swype, guessing it was from being on SD card.. so... ran a2sd remove, then a2sd cachesd.. swype problems gone.. my question is, now that i'm only running davlik on sd, is it safe to use gingerbread's or titu's Move App To SD card for certain apps? or is there a better way?Hope everyone checking this out has luck.. I would but don't have time currently reflash if something goes wrong.. One thing I did notice is that it said that BusyBox 1.18.2 or lower was a requirement and you would receive errors on anything higher.. Not sure what 0728 comes with normally or if TITU installs it but it is showing BusyBox 1.18.4.. Downgrade may be necessary to make it probably work.. Just a thought, don't honestly know as i haven't tried.. Throwing it out there![]()
