I'll try formatting the sdcard tonight. I tried the beta because it's always worked well for me in the past. Had issues with 2.7.5.2 a few months ago. But I trust you guys' judgment so I'm giving it another shot
Quick question... I've noticed a few people saying that they don't use TIBU anymore.. So what do you guys use to restore apps?? Do you just restore the sd-ext to get your apps back??
I do a advanced restore of the data.img from my backupQuick question... I've noticed a few people saying that they don't use TIBU anymore.. So what do you guys use to restore apps?? Do you just restore the sd-ext to get your apps back??
I do a advanced restore of the data.img from my backup![]()
Really? This is the first time ever, my swap actually activated on boot. Ive always had to run the TE commands to activate it. Wonder why it isnt working for you.
Is that safe to do when going to a new build? Or should i do as ShinySide says and redownload everything for a new build?
That's all you do? Advanced restore > restore file > restore data? And you get all your apps back? Do you get the user data as well?
(Actually, I'm gonna reflash and see for myself.)![]()
just downloaded the new rom, AWSOME as always. i flash the Metroff, & now the Roaming Indicator Off is showing. i flashed it 3x no go. is that the correct one to load? or am i missing something?
What happened to the 0728 build and the other Gapps? It's not on the wiki anymore, and I just deleted it from my phone...
This would be correct, I linked the 0613 gapps back because the 724 ones were not listed anywhere else n ppl were having issues with em. Soon as the newest gapps are reported working well I will link those. And all gapp versions can be found on goo-inside-me for those who want the newest of a later version.The new build replaced it. PG probably did that because the new ones are pretty much an update of it. I have the rom and gapps. I can post them in a bit if you want them.
never had to flash dta2sd with my buildsand with the gui no you dont have to use terminal anymore
You mean on the dropdown notification? I can fix that too. I added the eri.xml back to the metroff to fix the banner issue on the Optimus C/M. But I can edit it some so nadda shows.![]()
Playfulgod I found something very interesting, maybe some other members can confirm it, well I hated the indicator roaming off notification that was in the status bar, so I only flash the 09/12 build and the gaps, and then I tried and the picture messaging worked and it doesn't show the indicator roaming off notification, it will if I install the metrooff fix, but I don't need it, maybe some other members with metro can confirm if you fix it in your build or maybe is and amazing glitch in my phone???
last week I added the eri.xml back to the metroff. I will blank the other line out too so it says nadda.I cant even tell you the last time I flashed the MetrOff and MMS works and Ive never once have had the roam indicator.
Toke, This is the link he posted above and it's also the one everyone uses for reference. CM7-Ascend - Prepaid Android This is a prepaid android wiki site. There is another site listed for more info too. CyanogenMod | Android Community Rom based on Gingerbread [Compliments of Isaacj87 and anyone else who is involved.]
What works?
Bluetooth
Wifi
GPS (see notes)
Sound
Accelerometer
Hardware keys
Trackball
Touchscreen
Lights
Apps2sd
Radio
Data services
Basic USB functionality
What doesn't?
Camera
USB mounting
Certain apps will take down the system (see notes)
Notes
Certain apps will take down the system (major slow-down). While the GPS works, Maps will cause instability. Camera has the same effect. In order to undo this, simply lock the screen and unlock it. CM7 should return to normal. I'm not sure the cause of this, but it's a top priority for me.
Angry birds doesn't install correctly. After it's installed from the Market, go into Applications
what I was trying to say is that I now received pictures without intalling the metro off fix, but doesn't send pictures, I wanted to let you guys know, because before the 09/12/2011 didn't even received or send pictures without installing the metro off fix, now in the 09/12 build does receive pictures but doesn't send them.
I'm just informing of what I found out if you didn't know.
all I did to take off the roaming indicator off, was delete the eri.xml from the zip
