Whats the differences between the 0912 build and the 0913 build?? Just that the max OC is 710??
nope bootsound has been in my builds for months now lolDo we still need to do the edits for bootsound?
yea in my builds you just have to change out the android_audio.mp3 to one you like n rename it the same.Ahhh I never tried to put a custom sound on your build. Only did it with BobZ's and had to copy and paste all those edits to the build prop and etc.
just wanting to know whats difference from rom 07282011 that playfulgod put on this rom 09132011 that he didn't put on the other rom?
DTA2SD GUI, 729 OC'd kernel, and probably a few fixes and other goodies. I think the lights have been fixed too.
The 912 build has 748 kernel.
I haven't tried it yet.
The 0913 only oc's to 710
The 0912 will oc to 729 and 748
other than that, lights are fixedOh, my bad. I was going from memory... as I said, I haven't tried them, just read about them.
I stand corrected.
other than that, lights are fixed![]()
that was prolly a fix from CM lolAnd the digital signal display works now, too. It's no longer stuck at 87 or whatever.
And OP would be?![]()
whats this light fix your talking about?
