kevinrubio
Android Expert
look at my comment before
hey it booted up and everything but now it freezes out of nowhere and turns off how do i fix this?
Do you have a "Lazy" Ascend? Have you ran 710 before? Because I noticed unlike other builds where the max is set to 600, 710 is set to the default speed. So as soon as you boot you are running 710
Yeah I would. Mine will run at 748 but begin to get glitchy and start to freeze. I have it @729 which is what Ive been running at on BobZ's build and everything is good.
lol i know right he forgot the "y" in playful
I like the new ROM PG, had an issue with it not booting, but I flashed my backed up boot .img and now all is well. Quesiton - On the Apps2sd gui, there is an option for swap, but it says it wont work with this Kernel. Any way around this you know of? Do you think swap helps with low ram device, or not really necessary?
did you fix it cause it works fine for me lol. And ROM Manager is good shyt, I use it and dont use tibuOk, I'm officially calling ROM Manager "bloatware."
At least ROM Manager is more useful than, say, a 10min trial of Midnight Bowling 2.
Swap is working fine for me.
umm why would you think a 'beta' would work or be more stable than a stable release? its working on mine, but I do not use tibu.Flashed the new version this morning and everything signed to be working ok until I realized that even though a2sdgui said that apps were on sd, they were still going to internal and tibu wasn't showing the ext. I ran a2sd check on terminal and it said something like my ext wasn't mounted. I tried a reinstall but that failed. I noticed that the rom uses DT a2sd version 2.7.5.2 so I tried flashing 2.7.5.3 beta 4. things were looking goods until it got to the fix permissions part. It rebooted about 80% through and would not boot. Then I tried wiping and reflashing and this time I flashed beta 4 right after I flashes gapps. But still no boot. Restored backup and am gonna try again tonight. I think my ext is ext4 and that may be the issue with 2.7.5.2. might have to repartition but hoping to avoid that.
