Taterhater88er
Member
YAY WE HAVE LIGHTS! Thanks to PG and everyone else involved. Seriously, thumbs up and bravo.
never had to flash dta2sd with my buildsand with the gui no you dont have to use terminal anymore
You mean on the dropdown notification? I can fix that too. I added the eri.xml back to the metroff to fix the banner issue on the Optimus C/M. But I can edit it some so nadda shows.![]()
Wait Does this build OC to 729?
yes even to 748Mhz but mine kept rebooting at that speed.Wait Does this build OC to 729?
nuttmeg will fix that for us
GB prolly has gotten more graphic heavy, thus has more cpu load which results in slower speeds on the lil ascendIs that a yes or a no? I attempted to swap things from BobZ to 7.2 to make it run at 729 but I was never successful.
no clue it booted on mine :\yo PG the new build will not boot know y... pretty sure i did everything right
actually mine doesn't boot up either bro.
mine is so lazy. is 748 MHz oc in this build?
if it is =, than thats my problem right there, lol my stupid ascend wont run that.
Didnt reboot but started to get glitchy. But 729 works beautifully for me, just like on BobZ build, which is literally all I really wanted out of 7.2 New build available:
CM7-Ascend - Prepaid Android
uploading to ROM Manager now
Attention nuttmeg, plz update OP plz sir![]()
I posted a link for the newest 0828 gapps in the "CM7 Random Issue Thread" Try those.
