Root [ROM][WIP] CyanogenMod 7 | Android 2.3.5 (Gingerbread) | Current Version: 09122011
I had backed up my missing apps and data on the phone's SD card and a folder on my PC. How do I get Titanium Backup back on my phone to restore these missing apps?
If you can still access the market thats where youll find it. If the titanium backup folder is still on your SD card you should be good to go.
re download it and install titu and download the lastest busybox by hitting the problems button. next click on backup/restore tab, now hit the menu key on the phone and select batch, you will now see option ton run like restore system app+data, run that and you should be all good.
when you click to restore app+data you have the option to uncheck any apps that you dont want.
Yeap. I noticed that the camera is there even though it is an on the CM7 applications for example. Would it put it in applications twice?
i wouldnt put the camera backup back on cause this is cm7 and the one titu has wasmade for 2.1, and that might cause force close and other slow down things to happen.
Can we do an apps to sd card app? I noticed lost a lot of internal phone storage from when I was using Icarus 1.0 Cricket.
yes...go to setting/cyangenmod settings/application, and put a check in the box that say Allow application moving. also under that you can choose install location.
That just moves future apps, correct?
you can move some of the apps thats currently install bygoing to setting/application/manage application and tap the app that you want to moveand tap Move to sd card, keep in mind not all apps will work if its move to sd card and some apps want move period. some apps have to be install to the phone like Angry birds for example.
a couple apps that won't work if moved are handcent and poweramp. finding more as i try to use them....
Thank you. :)
That opened up even more internal phone storage than Icarus!!! :eek:
Is there any issue with moving Maps to SD? I know there was an issue with Maps to begin with.
How do you end a call now? The end call button just turns the screen off.
BetterKeyboard wouldn't work. Force closes. :(
open your app draw, spare parts, setting for the end button is in there.
I use Better keyboard and dont have no force closes.
I guess I could try reinstalling Better Keyboard and see if the same happens.
Do you know how to get rid of that Roaming Indicator Off message (scrolls across the top after my screen comes back on)?
I guess I could try reinstalling Better Keyboard and if the same happens.
you are using BK 8 right?
Yea i got that too n cant get rid of it lol
Yeap. The Android keyboard actually doesn't lag like BK 8 does but I like BK8's talk-to-text for text messaging.
How do I disable the stock messaging so I don't get two notifications for text messages?
umm lost on the stock messaging, theres only one msg app I know of on there lol. I havent noticed getting dup notices for txt.
Yea the android kb seemed less lagging, but I tend to typo more with it vs BK lol. I like the symbols on long press in BK.
I'd also like to now how to turn off the Roaming Indicator. It annoys me so much. I looked through the settings and couldn't find anything about a Roaming Indicator.
Are you using another messaging app? If so, go into the settings of the stock messaging and disable notifications ;)
If have SMS installed for text messaging. I believe I had the same problem with Icarus.
moved the bk8 to the phone, works better and no force closes, this is also another app that have issues i believe when it is install to the sd card.
