PlayfulGod
Extreme Android User
lol tats when I notice it thr most is when I am typing fast, but its happened just thumbing it too lolThe android keyboard is a little too laggy for me (I text really fast!) lol
Yep. I just try to stick to Smart Keyboardlol tats when I notice it thr most is when I am typing fast, but its happened just thumbing it too lol
just put the .zip from isaacs wiki on your sd card using a card reader. you can also use adb to push through to cwm or (if you followed directions to the T) restore your previous rom. at worst follow this thread to flash back to stock....
http://androidforums.com/huawei-ascend/282038-how-flash-huawei-ascend-stock.html
Progress is progress. That's great to hear. I hope that someone decides to pick up where you left off so that we can "perfect" our AscendsOh, BTW! I got the electron beam animation to work on the Ascend, but it goes frame-by-frame. Looks quite nasty LOL
+1Progress is progress. That's great to hear. I hope that someone decides to pick up where you left off so that we can "perfect" our Ascends
Thanks so much for all that you have done for our Ascend community Isaac. Your work is greatly appreciated.
sweet isaac.
? for ya, can you tell us how to properly apply the CWM 3.0.2.4 update? Mine keeps downloading it every time I try too from CWM n still says 3.0.0.5 for the cwm recovery and 3.0.1.4 for rom manager. I've put the img file in the cwm/download/mirrorbrain/cwm.com/recoveries/ folder n run the flash cwmr from rom manager.
fastboot flash recovery recovery-clockwork-3.0.2.4-ascend.img
Thanks, I'm following the guide on the cm wiki on installing the SDK's etc.You'll have to use fastboot.
Put the phone is fastboot mode by pressing and holding VOL DOWN + END CALL and POWER. It will stay at the white Huawei screen.
Then use fastboot to flash the recovery onto the phone:
That'll do it. I won't go into more detail as there's so many guides out there.Code:fastboot flash recovery recovery-clockwork-3.0.2.4-ascend.img
I love learning new shyt
Thanks for the support, guys.
As of now, I'm still hacking away at the Ascend. The build I promised a couple days back is coming today. I finally got GPS working again with the new libs. The new build will be in its usual spot.
Isaac
SO a complete wipe needs to been done for this build too?New version of CM7 is up. Consume and be happy.
I figured as much n tried w/o wiping n it got stuck after the boot screen, re-flashing now...I can never say. I HAVE to wipe every time because I need to be sure my changes during builds work.
Technically, you could flash without wiping, but it's really up to you.
really like the new boot screen too, anyway to replace the white one?
Great work too isaac I really appreciate the time you put into this so we all can have the latest n greatest w/o waiting on carriers n manufacturers![]()
it lists whats working, not working, added on the wikiwhats new in the updated one.
