PlayfulGod
Extreme Android User
We're talking about MMS not SMS, there is a diffMust be a metro thing. I use SMS a lot and havent had any problems. (cricket)
SMS = text msgs
MMS = multimedia msgs
correct me if I am wrong, but wasnt this the same on 2.1?? lolAre you mounting the SD card on your phone and computer. In CM7, drag the status bar down, click the 'click to transfer files' button and something will pop up on your computer. Just click open folder to view files. That should do it.
ahhh,, lol at the lil things we forget when we move up to custom roms lolNo a pop up came on the comp and you just pushed it there.
it worked the same for 2.1. you needed to push the enable button your your phone not pc.
Could you get this mms fix to work for CM7 or at least so it installs so one of us could test it for you???
[4.13.2011] MetrOFF v1.1 | MetroPCS One-Flash-Fix [MMS] - xda-developers
I tied flashing it and it aborted with a scripting error, something about switching to Edify.
kewl thxgot it to work with cm6, but not cm7but all is good, i had check on [4.13.2011] MetrOFF v1.1 | MetroPCS One-Flash-Fix [MMS] - xda-developers and theres suppose to be another GB version being work on for cm7.
ummmm maybe I need to flash my backup n start fresh lol
and apk???? dont ya mean zip![]()
cant hurt to tryAny way this could work for cricket?
port 8080 really??? lmao I bet they have alot of packet sniffers on that port lol
Metrololz might be...btw what carrier your on play?
