CRUMBsnatcher
ummm good question I cant find it either lol, use to be in the settings in the camera wasnt it?
Yeah, on stock and Icarus. But it's nowhere to be found in cm6/7.
Only thing I ask and im new with this is wheres the app market?
Could just go into the sound and add a x to the shutter sound lolYeah, on stock and Icarus. But it's nowhere to be found in cm6/7.
Did you flash Gapps?market should be install already..you might have to reflash it if its not in the apps menu...
yup and at first boot the setup wizard will popup.No and I just found out what gapps was, I basically just put it on sd and use cwm and flash it?
dunno I just have a 2BG card so I've not tried many games lolHi,
Does anyone else with CM7 have in issue with games on the SD Card? Very few of my games will work if I put them on the SD Card. They all just force close as soon as I open them. I'd really like games to work on the SD Card because thats what takes up the most space on the phone.
Hi,
forget the 2.2 update. This is way better.
yup lol, I wonder if its the app that sux or a driver issue?? not to mention the camera is a pos anyway lolNow if only the camcorder worked... hahaha![]()
Soon as I get any spare cash I'll def buy you a beer Isaac.New build (04162011) is available, read the changelog for the goodies. I'll add my donation (beer money) link on the wiki as well. Buy me a beer if you like what I'm doing.
Is this build more than just the mms fix added?
k thx, now to decide if I wanna start over atm lolYeah, I guess you could say that.
It has live wallpaper support now, CC and swap for more memory "room", Has the CM7 themes back (I think you were asking where they went), stability fixes.
Great job isacc and thanks for your time n effort.
metro mms working for you nuttmeg?
ah ok, same fix wouldnt still work to fix it?Metro MMS may work with the fix you applied to 2.3 eariler. I think I f'd up the APN list and I'll push a fix to my Github later.
