ah ok, same fix wouldnt still work to fix it?
It might, but I think the Metro APN is gone from the build. It needs to be re-added.
Upvote
0
ahh ok nuttmeg n myself had it working for metro with the fix so tats prolly it then.It might, but I think the Metro APN is gone from the build. It needs to be re-added.
Just del the old one n replace it with this with a root explorer?
oh I'll test it sorry, wife was texting me lol.so wait basically, mms for METRO PCS users does not work still right?
the last build with the mms fix applied metro works.aww..forget it then, i was abt to flash, i guess iiil jus stick to the last update 4-05-11 for now untill mms is done
that build with the GB MMS Fix released yesterday and it works yes.what u mean last build...the last build was on 040511
that has working mms?
Flashing now. I can't wait to try this on!!that build with the GB MMS Fix released yesterday and it works yes.
to flash the fix you need CWM 2.5.1.8 tho
If you have CWM 3 install n dont want to downgrade it to 2.5.1.8 then I have a backup with the last build with the fix up loaded n posted on page 11 of this thread.
Why do you need to tether a laptop with the phone??? via wifi anyhow?Thank u so much now if i can get wireless tether to work on the windows XP laptop lol
I have a cross between the cyanbreadx n Blux AS themes lol. Droid font, n wanna figure out how to make the status bar bg transparent.
I just modify existing themes atm,How do you make themes? Like either from scratch or edit an existing one? Any specific program?
heard metamorph didnt work so well in CM7.The only thing i have found on making the status bar transparent is with metamorph, then unchecking the wallpaper hack in most launchers. Don't know if that is any help.
