PlayfulGod
Extreme Android User
grrr market still fc's, done cleared the cache, any other ideas?
i think i figure out why it didnt work, did you put you apn setting in and backup rom?
only thing u need to edit is the username n passwd.when i did the apns erlier i saved them but the only one that shows up is the cricket one so i cant check it but im going to try again
in APN settings do a reset. then just make sure to have it enabled n then to the fix.
just enable it n then to the fixWhen i go into the apn settings theres only cricket but if i hit menu then reset default theres metro too i can check the circle there and get in and change what i need to but when im done and hit save it dont i can hit back but the metro option is gone again leving only cricket the metro apn is gone again its one thing after another with this phone im looking foward to an eventual upgrade from this pain in my butt to what i dont know yet but im sure todo alot more reaserch next time
You on the current build or still 04052011?Thats the problem tho when im done i cant find it to enable it its gone again unless im exiting the wrong way i dont know im starting to think im missing somthing
k, then you need to replace the apns-conf.xml with the one off of isaacs github link he posted.Im on the current build now was on 04052011
on the latest build for metro you have to replace the /system/etc/apns-confi.xml with the one isaac posted a link to. Then Reboot. then flash the fix with CWM 2.5.1.8. After that you dont need to change anything except for the username to 'your#@mymetropcs.com' and the passwd to 'metropcs' and save.
NOTE: after the fix metropcs will show up twice in the APN settings, you want to use the 2nd one with #777 as the APN.
Only thing that show was for Cricket when I flashed the new build. I trust ya and I'm not gonna reflash just to see lol, couldnt count how many times I flashed my phone since friday loli just flashed the fix after the first boot and it works fine. i'm using the 04-16 version.
*apn shows up once and was not even selected when i pulled it up to check the settings.
just texted me after selecting and worked.*
i didn't change any settings or anything. metropos.
apn settings:
metropcs
wap.metropcs.net
not set
not set
MDN@metropcs.net
Http://mertopcs.net/mmsc
not set
3128
310
027
notset
default,supl,mms
it goes in /system/etc, do this with a su root explorer. Then reboot, then reflash the fix.
I didnt sign up on it. I copied n pasted the code into notepad++ and saved it as apns-conf.xml.I tryed to get that file but i think i got the wrong one i think i have to sign up to that site before i can d/ld it either way ill look into it tomorrow after work i hope its a big job cuz i need the f'n money
Bottom line is it works lol, but my settings are different than yours, they're like what nuttmeg posted on his howto thread.
Question Toke, can you send and receive mms? Think nuttmeg send he could receive n not send earlier. I get n can send.
so you just flashed the new build, booted, flashed the fix, and you were good to go? I'm sure that will help others out alot lolsend and receive just fine. less than a miute to get my own and two to get one from spyder in penn.
Oh I got mine working my way lol, but how you did will be easier for others.updated my guide http://androidforums.com/ascend-all-things-root/309499-how-install-cm6-7-comprehensive.html
just follow the steps as you read them and you should be good.
Originally Posted by PlayfulGod
I uploaded a copy of the CM7-Ascend ROM with the mms fix applied and working. Only thing needed to make it work is:
isaac please feel free to use this to update your links, as I did nothing compared to the work you've done on CM7. I just thought this would make it easier for some of the newbies.
- Download the zip.
- unzip it and move the inner folder to /clockworkmod/backup/ on your sdcard.
- Reboot in to recovery n scroll down to backup & restore, restore, select the folder you just put there and run restore.
- Reboot.
- Once booted goto the app drawer and open Voice Dialer.
- Say 'OPEN A P N', a box will pop up with MetroPCS and Cricket
- Choose your carrier.
- Edit the username and enter you # where it says 'yourphonenumber'.
- Click menu and save.
- Enjoy mms on 2.3.3 Gingerbread!!
Note: All credit goes to isaac and all those who helped him bring us CM7 on the Ascend!!! All I did with nuttmeg's (nuttmeg figured it out) help was get it installed and made a backup and zipped it
CWM 3 will be needed to flash this zip.
CM7 with MMS Fixed
Gapps will still needed to be downloaded from the OP and installed.
this didnt work for me either it was an md5 mismatch any ideas?
settings/accounts & sync, add your google account.First, I would like to say. Thank you very very much. This is amazing.
Just a quick question. I denied something in the market which I'm noticing was the Google Apps. It said it would give me the option to return to it if I wanted to turn on wi-fi. So I rejected it, how do I get to that window again?
