Is there an instruction to install this ROM?
check the power tweaks in the cyanogenmod settingsTo Isaac: Just a suggestion to implement if you get the free time. Battery percentage on the notification screen, when you drag the status bar down. That would be pretty cool.
metro mms working for you nuttmeg?
I'm a bit confused. Is this safe to update to? I'm running icarus now, but I'm looking to get more speed without bricking my handset.
thanks it worked lets hope everythings else do tooI uploaded a copy of the CM7-Ascend ROM with the mms fix applied and working. Only thing needed to make it work is:
isaac please feel free to use this to update your links, as I did nothing compared to the work you've done on CM7. I just thought this would make it easier for some of the newbies.
- Download the zip.
- unzip it and move the inner folder to /clockworkmod/backup/ on your sdcard.
- Reboot in to recovery n scroll down to backup & restore, restore, select the folder you just put there and run restore.
- Reboot.
- Once booted goto the app drawer and open Voice Dialer.
- Say 'OPEN A P N', a box will pop up with MetroPCS and Cricket
- Choose your carrier.
- Edit the username and enter you # where it says 'yourphonenumber'.
- Click menu and save.
- Enjoy mms on 2.3.3 Gingerbread!!
Note: All credit goes to isaac and all those who helped him bring us CM7 on the Ascend!!! All I did with nuttmeg's (nuttmeg figured it out) help was get it installed and made a backup and zipped it
CWM 3 will be needed to flash this zip.
CM7 with MMS Fixed
Gapps will still needed to be downloaded from the OP and installed.
Screenshots:
Hello all. I just flashed the cm7 mod posted on page 11 and followed all the instrucions to a T and I still dont have mms on cricket service. I double checked all the settings in "open APN" and saved the settings. I have asked several people including my wife to send me mms and still have not received any
umm isaac I think you got your 6 & 7's mixed up in there
And I've seen what you are talking about. Just with the themes for CM7 on the better phones look amazing lol.
And again I'd like to think you isaac for all your time and effort in put into this so we can get a taste of 2.3.
I just wanted to prove that BS wrong. Just 2 cents from the guy that ported both.![]()
no clue it restored when I tried it. Theres a new build out now any howOriginally Posted by PlayfulGod![]()
- Download the zip.
- Reboot.
CM7 with MMS Fixed
this didnt work for me either it was an md5 mismatch any ideas?
check you PMive tryed this morning to get the mms working i have cwm 3.0.0.5 i d/ld the MetrOFF.v1.1-MMS-[GB]-[CM_AOSP].zip file i beleive to be correct but i get an instalation aborted message when tryn to flash it it says
--installing; /sdcard/metr0ff.v1.1-mms-[gb]-[cm_aosp].zip
finding update package...
opening update package...
installing update..
amend scripting (update-script)
is no longer supported
amend scripting was depreciated by google
in android 1.5. it was necessary to remove it when
upgrading to the clockworkmod 3.0 gingerbread based recovery
please switch to edify scripting (updater-script and update bianary) to create working .zip packages
instalation aborted
does this mean i need a diff cmr if so where can i find it?
no clue it restored when I tried it. Theres a new build out now any how![]()
nope I edited it to 'yourphonenumber'i think i figure out why it didnt work, did you put you apn setting in and backup rom?
