CRUMBsnatcher
So this legit works?
Sure doesSo this legit works?
nutmeg and myself and a couple others have it working. If you have CM7 installed already just follow nettmeg's howto (he has a thread on it too) or if you are just installing CM7 feel free to use the link I provided until isaac updates his.Ok. So I flashed CM7, now. I am still in CWM. I have installed CM7 zip but when I go to install the zip for the mms ... it aborts. What to do?I uploaded a copy of the CM7-Ascend ROM with the mms fix applied and working. Only thing needed to make it work is:
- Goto the app drawer and open Voice Dialer.
- Say 'OPEN A P N', a box will pop up with MetroPCS and Cricket
- Choose your carrier.
- Edit the username and enter you # where it says 'yourphonenumber'.
- Click menu and save.
- Enjoy mms on 2.3.3 Gingerbread!!
isaac please feel free to use this to update your links, as I did nothing compared to the work you've done on CM7. I just thought this would make it easier for some of the newbies.
Note: All credit goes to isaac and all those who helped him bring us CM7 on the Ascend!!! All I did with nuttmeg's (nuttmeg figured it out) help was get it installed and made a backup and zipped it
CWM 3 will be needed to flash this zip.
CM7 with MMS Fix!
Gapps will still needed to be downloaded from the OP and installed.
if ur using my zip u dont need to flash the fix. its already flashed toOk. So I flashed CM7, now. I am still in CWM. I have installed CM7 zip but when I go to install the zip for the mms ... it aborts. What to do?
umm dumb? skeered? conservative? lol, its all a personnal perf, but its a no brainer to me lolWith mms working any reason not to flash I'm still running slow ass stock..![]()
otherwise you have to downgrade CWM to 2.5.1.8 to be able to flash the fix. Hence why I did this to make it easier on you all![]()
what version of CWM u using? is it green or orange when booted into CWM?Im trying to flash your rom using cwm 3 but when i choose install zip it aborts, what can I do just flash back to previous cm7. I dont have a rom istalled currently because Im doing a fresh install and trying to use your zip but am having issues. maybe Im not wording myself right here...but I am getting kinda frustrated lol
ummm I'm purdy sure I was CWM 3 when I backed it up lol, I'll check mine.orange, followed your directions for install
k I might have not flashed to CWM 3 like I thought lol. I will flash it back n back it up on CWM 3 n re-upload it. If you are aready got the setup to flash CWM 2.5.1.8 u may try that while I work on this.Yea it installs the original cyanogen mod fine but it aborts when I try and install your version
Oh and sorry for the confusion, I'm taking of my dad who has stage 4 lung cancer thats spread to his bones, so I dont get much sleep.
+1Remember all if you are installing a fresh copy of cm7, make sure you let it bootup for the first time before applying the .zip file...
yup tats it basicallySo let me get this straight. Flash CM7 wit orange CWM, then boot up, setup, change apn, then flash to green CWM, then flash fix right? Just want to be sure. THIS idiot tried to flash after CM7 like it was gapps or something.LMAO!
ummm good question I cant find it either lol, use to be in the settings in the camera wasnt it?This is very off topic, but how do you turn off the shutter sound in the camera? I've looked everywhere and can't find anything.
