On stock and Icarus the autorun.iso has the usb n various other drivers needed. On CM6/7 the iso image has nothing but a dummy image and neither is setup to run the iso as a cd like stock/icarus is. I messed around with this last week to try and get it to work with no luck, something isnt coded for it to work. Also the original iso is over 11MB which is a big hit to internal RAM/storage.
The last i knew no it was not but i may be mistaken. You used it on a public computer?
No, you broke you're phone not this or any other ROM. I suggest you go back to being a Troll!OK, this thing, if you can call it a ROM, borked my phone. When i press the on button my phone now turns into a wise talking cat, WTF Isaac? This cat has threatened to kill me and my loved ones. The cat is choke-resistant, I've already tried.
I doubt it, but ya never know. but with the newer kernel def can make things run even better and get other things to work better.If you we got . 32 kernel will we be able to overclock higher
Hi Joe. Long time no see. Looks like your skills are still quite marketable in the troll region! ^_^OK, this thing, if you can call it a ROM, borked my phone. When i press the on button my phone now turns into a wise talking cat, WTF Isaac? This cat has threatened to kill me and my loved ones. The cat is choke-resistant, I've already tried.
got me lol, then again I'm not all here atm so lolHi Joe. Long time no see. Looks like your skills are still quite marketable in the troll region! ^_^
If choking doesnt work swing it by the tail
Now that's trolling. LOL. I was beginning to think you lost your touch, man.
The next build is definitely cat-proof. But you'll have to keep choking the kittehs.
Is there a problem with recieving mms on cricket with build 0514. Sorry if this has already been addressed. I keep getting "Download was unsuccessful". also is the overclock addition on rom manager? Again, sorry if this has been addressed.
hello everyone, i was wondering how do you upgrade clockwork mod 2xxx to 3xxx. I'm currently running cm6 and wanna try cm7, my friend says cm7 is a beauty . I downloaded the clockworkd 3xxx to my comp but it's in img format, I'm not really familiar with this format
how do i upgrade my current clockwork?
Thanks for your help
