nuttmeg
Extreme Android User
I wish I knew when we were gonna get a new update for it.
its 99.9% finish, really stable with this latest build, but atm isaac had put it on hold, so just be patient...
hey, im new to this whole thing. hope im not being your typical annoying forum noob. But i really want to put gingerbread on my huawei ascend. and being new to this whole thing im not exactly sure of all of the terminology and whatnot. i know how to root my phone but thats about it to be honest.
I need to find this build i would like to know if my ascend is capable of anything over 710MHz its eating at me like rust on a ford I need to know or i might just lose it lmfao
Good to know.. I'm getting twitchy to flash something lol.. Might have to flash PG's 2.2 to check it out and get my fix
Use this GAPS with the latest CM7 build.1ST 20110307 universal recommended for cm 7.0x for android 2.3.3
2ND 20110120 universal no longer supported for android 2.3.2
3RD 20110115 universal no longer supported for android 2.3.2
4TH 20110114 universal no longer supported for android 2.3.2
can some explain what is this for
Its finally fixed! Thank you! ))
have you tried setting up your static ip address in advance setting in WI-FI so it can recognize your Mac Address? my girlfriend phone did that conneting and disconnecting until i fixed it now shes running WI-Fi no problem.
But how do u install it
Hi everyone!
Normally I tend to just lurk, but I've really screwed myself now. I'm trying to flash cm7 on my ascend. I followed the instructions in the guide, which were very simple; root, cwm v.3, back up etc. but my phone is stuck in a boot
loop. I cannot get to cwm and my computer is not detecting my phone. Any ideas or help would be MUCH appreciated.
Have someone call your phone to knock it out of the loop.
Hi everyone!
Hi everyone! I'm new here been following the forums for a while. But have run into problems myself now and need asap help. I flashed icarus1.1 and liked it but decided to flash cyanogen/7 because i couldn't fix my mms problem (tried everything) including mms fix (to the letter) and re-flashing several times.
So i flashed cyanogen/7 few days ago and its the best thing that ever happened to my phone lol but ran into problems as well. Everything works fine except i cant install any apps. They download, then once they try to install it goes into the cyanogen mod 7 loop thingy for a while. Then once its done the app isn't even installed. I don't have any of the Gapps, even though i flashed the Gapps zip.
I also cant recover any of my apps i have on my SD card. I see them in the file manager and also under applications, it gives me the option to uninstall but they're not installed. Another thing is when i tried to restore data to my phone, under CWM it didn't restore my contacts so i had to restore them through the Vcard file and now they're all out of order, as in not alphabetized. (i don't have them backed up through Google, Sadly) but will once i fix everything.
Also if this helps, (which I'm sure is a grave mistake by my part) whenever i flashed a new Rom i would advanced restore only the data of my backup to my new Rom. As i saw this as the only way to get back my (Data) apps, contacts, texts etc. Titanium backup and i don't get along. As in i don't like it and didn't work for me when i attempted to restore things. So for example, when i flashed cyanogen/7, i restored the data of the backup i made while icarus1.1 was flashed on my phone to get my data back. And i think i still have both CWmods on my phone. The one you need for icarus1.1(2.5xx) and currently the one you need for cyanogen/7 (3.xx5)
I don't know how to get rid of (2.5xx) so i kinda just flashed the latter over it. I do boot into recover mode v 3.xx5 though, so no worries their.
My phone status as of now is an endless cyanogen (mod) 7 loop thingy, constantly loading. Ever since i changed the app install to settings from automatic to internal.
So as you can see my phone is in a swamp of problems right now and i need all the help i can get to take it out asap. So pleeease all you great people I'd really really appreciate it if you can help me out as best you can. 1 step at a time, we'll get this done i gotta get my phone fixed soon as i have things to do that cant be done without my phone lol. I am patient so no worries. Thank you very much. hope to get help soon
